Trouble starting 4.3
Old Nov 22, 2018 | 12:31 PM
sportsdaddy11's Avatar
sportsdaddy11 is on a distinguished road
Default Trouble starting 4.3
I'm working on a 2002 2wd Blazer and put a new fuel pump and relay in it. I put the fuel pressure gauge on it and it shows over 60psi when pump kicks on but immediately drops after and takes about 4 times cranking and pumping the pedal to get it to fire. Now my question is before I just start hacking around is the spark not hot enough? Is the fuel pressure supposed to drop off like that and if not what could cause that. Or is there not enough pressure coming from the fuel pump? Thanks guys I love reading through here as it's really helpful
Old Nov 24, 2018 | 12:54 PM
go chevy's Avatar
I can't help you here, just wanted too wish you luck on the problem... There are a ton of good people here at Blazer Forum and I am sure sooner rather than later you will find the advice you need.
upmaine
Feb 18, 2012 09:45 AM
jobe05706
Jun 25, 2010 04:24 PM
brianroark
Jun 25, 2010 03:14 PM
RIFLEMAN 308
May 7, 2010 06:23 AM
Jorgen
13
Aug 2, 2007 08:05 PM
