Turning the key. No "System check".
I have some electrical problem on the car. The windows wont work.
I changed the battery (did not survive the winter) and drove the car from the garage. I drove about 150 meters and turned off the car. I removed the dashboard to look for grounding points. Now the problem. Turning the key and i dont se that the car does the "system check" on the dashboard. The engine do crank, but no spark. The car i a 1997 Blazer. An suggestions?? UPADTE. NO bulb test on egnition on. No resplonce on OBD2. |
Replace the ignition switch
Strange problems.
Replacing the ignition switch. Problem solved! |
