Turning the key. No "System check".
Old May 5, 2012 | 12:27 PM
gotlandia's Avatar
gotlandia is on a distinguished road
Default Turning the key. No "System check".
I have some electrical problem on the car. The windows wont work.
I changed the battery (did not survive the winter) and drove the car from the garage. I drove about 150 meters and turned off the car. I removed the dashboard to look for grounding points.
Now the problem.
Turning the key and i dont se that the car does the "system check" on the dashboard.
The engine do crank, but no spark.
The car i a 1997 Blazer.
An suggestions??
UPADTE.
NO bulb test on egnition on.
No resplonce on OBD2.
Old May 14, 2012 | 02:15 AM
gotlandia's Avatar
Default Replace the ignition switch
Strange problems.
Replacing the ignition switch.
Problem solved!
changeme20
Oct 24, 2020 02:12 AM
doccheese
Dec 12, 2014 03:43 PM
richphotos
Aug 26, 2012 07:15 PM
midnightmekanik
Oct 8, 2009 08:32 PM
oisinirish
Oct 7, 2009 02:12 AM
