Very high idle
Old Jun 25, 2009 | 02:06 PM
offroaddad1105's Avatar
offroaddad1105 is on a distinguished road
Angry Very high idle
:icon_ doh:I have a 95 blazer with the 4.3 vortec and when u start it, it runs like you have the gas to the floor, ive replaced the tps and idle control valve and egr valve, plugs and wires, and the coolant temp switch whats next??
Old Jun 25, 2009 | 06:29 PM
Finding the source of your large vacuum leak should be high on the list.
Old Jun 25, 2009 | 08:00 PM
ok found a vaccum leak and it didnt help. i scanned it and it reads- tps circut A low input...??????
Old Jun 27, 2009 | 12:23 AM
Blazercrazy's Avatar
Blazercrazy is an unknown quantity at this point
Try disconnecting the choke maybe its shot
Old Jun 27, 2009 | 04:31 AM
95POSmoneypit's Avatar
95POSmoneypit is on a distinguished road
When you replaced the IAC, did you clean the port it sits in? I pulled mine a few days ago and it fell out in 3 pieces. Put it all back together and cleaned the sensor and the whole and mine quit idling at 3k. Also may try cleaning the contacts on all the connectors to the sensors in the area (map, iac, tps, ...) Also found a nice little leak on the vacuum canister while replacing the lines. Looks like the last owner broke off the nipple and shoved it back in there with some chewing gum...
klote82
Apr 27, 2012 08:22 PM
danb2760
Dec 24, 2010 04:08 PM
pappyam
Dec 5, 2010 08:25 AM
dart
Feb 8, 2008 09:49 AM
Kellen
Sep 22, 2006 04:41 PM
