VERY rough idle, shakes violently and dies unless accelerator is pressed... help!
Old May 28, 2017 | 08:26 PM
92_S10_4x4's Avatar
92_S10_4x4 is on a distinguished road
Default VERY rough idle, shakes violently and dies unless accelerator is pressed... help!
At first I thought it may be the starter, as it wouldn't even click for a while, then replaced the air and oil filters, and oil sensor switch. I'm thinking it may be the fuel pump, but I want to be sure before I go putting in MORE parts that I don't actually need...
EDIT: Am now thinking possible misfire, have double checked firing order and spark plugs. Maybe bad distributor and/or cap??
1992 S10 Blazer 4.3 cylinder TBI 4x4
Old May 29, 2017 | 11:09 AM
akira6968's Avatar
akira6968 is on a distinguished road
I just ordered an obd2 scan tool from Amazon for about $13. I'm guessing you'll have better luck if you can provide some diagnostic details.
-noob non-mechanic
Old May 29, 2017 | 11:25 AM
92_S10_4x4's Avatar
Well, it's a 1992 so it's OBD1, and the light only comes on when it's already died; which it's supposed to do. Or else I would have done that already.....
Old May 29, 2017 | 11:37 AM
akira6968's Avatar
yikes. my apologies. I hope you can get some help and get it figured out my '00 is acting similar, but starts at least. good luck
Miketalley87
Apr 1, 2021 12:05 PM
hew2702
May 3, 2015 09:58 PM
klote82
Apr 27, 2012 08:22 PM
danb2760
Dec 24, 2010 04:08 PM
RedOctober
Oct 10, 2006 02:06 AM
