Weird Coolant Problem
Old May 14, 2013 | 09:40 PM
zball94's Avatar
zball94 is an unknown quantity at this point
Default Weird Coolant Problem
I parked my blazer on the street. When I came back, I noticed leaking coolant below it. The resivoir was dry. Anyway I drove back to the hotel (1 minute drive) and left it overnight. In the morning, I poured water in and started it to find the leak, but nothing! I drove around till it was at full temperature, and it performed normally with the water. Any idea what this phenomenon could've been? Thanks.
Old May 14, 2013 | 09:58 PM
Year, make, model, & engine? If 96 or newer, probably leaky lower intake manifold gaskets, very common problem.
Old May 14, 2013 | 10:32 PM
zball94's Avatar
It should be in my sig, if not its a 98 blazer zr2 4.3L
So that would cause it to either drain completely or hold 100%? I find it weird for it to go full-dry so suddenly then hold water without any drips at all right after.
Old May 14, 2013 | 10:54 PM
Twip's Avatar
was the radiator empty as well, or just the bottle?
Old May 15, 2013 | 12:13 AM
zball94's Avatar
I didn't check the rad, but it must've at least been low because the engine was operating slightly hotter than it usually does.
AcerDeucerQ
Dec 3, 2012 06:29 AM
hotrodsbyg
Aug 15, 2011 11:47 AM
Skeeter Cruz
Mar 4, 2010 07:07 PM
gERgMan
Sep 6, 2008 07:27 PM
Blazerx85
Jun 20, 2007 12:00 PM
