What is this part?
Old Apr 9, 2012 | 08:07 PM
89Recon's Avatar
89Recon is an unknown quantity at this point
Exclamation What is this part?
I found a huge crack in this part (see photo), I am not sure what part this is but the crack is about 6-7" long running down and around the back side of it. Is this a necessary part to have? or can I just remove it? I had a mechanic at my local Les Schwab look at it and he said to just remove it and it will be fine (of course I didn't ask him what it was called though I know I should have just didn't think of asking) but I wanted to get some 2nd opinions before I go taking a part out.
Old Apr 9, 2012 | 08:18 PM
dano440's Avatar
dano440 is on a distinguished road
it looks like a vacuum tank...
Old Apr 9, 2012 | 08:26 PM
x2 on the vacuum tank.
Old Apr 9, 2012 | 09:11 PM
89Recon's Avatar
Is it a part that has to be on the vehicle? the mechanic told me that I could just take it out?
Old Apr 9, 2012 | 09:18 PM
Yes, it needs to be there. Well, that is if you like having your HVAC stay set properly or your 4wd stay engaged when at high throttle angles where vacuum in the engine drops. Of course that requires a properly installed & functioning check valve in the system as well. Vacuum diagrams are in the NV233 threads found in the tech article section.
But your mechanic gets to fix those problems when you have them so it's a win-win for him to recommend taking it out.
Old Apr 9, 2012 | 09:36 PM
volfan4's Avatar
volfan4 is an unknown quantity at this point
Talking
LOL.... good one.
Old Apr 9, 2012 | 09:53 PM
89Recon's Avatar
thanks for the help much appreciated
Old Apr 9, 2012 | 11:20 PM
Rottidog's Avatar
The vacuum orb or canister is used to "store" excess vacuum so your HVAC, 4wd actuator have the needed amount of vacuum at high engine speeds to operate properly.
Like was said above, if it's removed the mechanic is just doing "job creation" because he's hoping he'll be the one to replace it for the NEW - no HVAC, 4wd problems that will arise.
It works in the reverse of an air tank on a compressor, same concept, just bassackwards.
spider21
Nov 17, 2011 06:27 PM
zynnad
Jan 14, 2010 04:29 PM
biniecki
Jan 7, 2010 02:07 PM
joeparker1968
Feb 14, 2005 06:44 PM
nerve_agent
Oct 20, 2004 04:21 AM
