What should I do next?
Old Apr 10, 2022 | 08:12 PM
Wytepirate's Avatar
Wytepirate is on a distinguished road
Well I e been off of the Blazer for a while, fixing my Dakota, and boat. Got the heli coil in the starter. Got the BFX scanner with dash commander. I'm probably gonna need a bit of tutoring on using this scanner though. Trying to learn it on my own has really frustrated me. As has this truck.
Old Apr 11, 2022 | 09:23 AM
LesMyer's Avatar
I dont intend to take over this thread from Tom A and Christine, but with their permission I will help with the Dash Command in reading Cam Sensor retard.
After installing the app did you buy the enhanced PIDs for your particular vehicle? This is done by choosing account in the right lower corner of the app.
Then enter a new vehicle using the "vehicle" button, connect to the vehicle computer, and validate the PIDs.
After this, you should be able to add cam sensor retard into the "data grid" and display it.
Dash Command has a half-decent user manual under "settings"
Here's the data grid on my phone as I have it configured, without being hooked up to the vehicle. Note cmp retard. Enhanced PIDs for Blazers all start with GM.
Old Apr 11, 2022 | 11:01 AM
. I have never messed with the cam retard. I'd defer to Les' suggestion as something.to try.
Old Apr 11, 2022 | 12:23 PM
LesMyer's Avatar
Sounded like you and Tom A and the OP were all talking about cam sensor retard. I'm just here to help facilitate reading of this value with Dash Command (since I was the one that suggested this software and the OP voiced frustration with it).
Old Apr 11, 2022 | 05:30 PM
Wytepirate's Avatar
Default Hopefully this will show you what I'm working with.
This is a screenshot of my data grid
Old Apr 11, 2022 | 06:47 PM
Wytepirate's Avatar
Where the vehicle is located the obdII scanner can't get wifi. Will this be a problem?
Old Apr 11, 2022 | 08:38 PM
LesMyer's Avatar
Connect to vehicle and display Data Grid. Press the + and then press add PIDs. Find the CMP Retard PID and select it. It will be added to your data grid.
If you cant find the CMP Retard PID when connected to the vehicle, did you buy the GM enhanced PIDs from within the app after installing it? When you try to add a PID to your data grid, are there any that start with GM? Did you make a "vehicle" in your app and then select it?
You dont have to be connected to the vehicle to buy the GM PIDs, that can be done wherever WIFI is available.
Old Apr 11, 2022 | 09:27 PM
Wytepirate's Avatar
Ok I think I've got them loaded now. I'll have to try it tomorrow evening. Thanks for the help.
Old Apr 12, 2022 | 06:21 AM
LesMyer's Avatar
Great, let us know.
Old Apr 12, 2022 | 06:16 PM
Wytepirate's Avatar
Ok the cmp retard PID is showing so what is the procedure for testing? KOEO it shows 0.0. KOER at idle it shows 56.3.
