What's this hole in the transmission?
Old Apr 4, 2015 | 06:06 PM
1stgen4.3's Avatar
1stgen4.3 is on a distinguished road
Default What's this hole in the transmission?
I bought my 1991 s10 blazer 4.3 a year ago. The clutch went out immediately so I got it replaced as well as the master and slave cylinder.
A couple weeks ago my clutch lost pressure and went to the floor so I got the master and slave cylinder replaced AGAIN. Luckily the parts were under warranty.
After I got the truck back I was looking underneath to check things out and noticed a large hole in the front bottom of the transmission near the crank case on the passenger side. It is about 1" in diameter and threaded as if a plug were supposed to go there. I think I can see the metal rod from the slave cylinder when I shine a light inside. Is this a inspection hole? Did the mechanic just leave out the plug? it supposed to be filled with fluid? Thanks for any responses
Old Apr 6, 2015 | 03:04 PM
Gambit66's Avatar
Gambit66 is on a distinguished road
Only thing that requires fluid on a manual transmission is the gear box, which requires gear oil. And if your clutch is hydraulic, that requires hydraulic fluid in it too.
K-BERTHABABY-5
Nov 20, 2009 12:01 AM
blazinloud
Headers, Intake, & Exhaust
May 8, 2007 11:22 PM
Hanr3
Mar 6, 2007 09:09 PM
BlazerDaughter
Jan 22, 2007 08:17 PM
XBlazer01
Nov 24, 2006 06:36 AM
