Who knows about transmissions?
Hello,
Changed my trans fluid the other day, and now it doesnt shift right. Reverse feels a lil sluggish, enough that I noticed, and it will not pull out in Drive. Have to shift to 1 to pull back in driveway. The only thing I can figure is a lil 1 x 1 square electronic thing dropped down while pan was dropped. Was dangling by a wire. I think I brushed it with my knuckle. IT WAS BARELY TOUCHED.. and I snapped it back in place. Thinking it is a solenoid but know little about a trans. I can NOT afford to take it in a shop unless its the only solution. Any ideas?? 2000 Blazer 4 Door 4WD |
Originally Posted by Greghshepherd@yahoo.com
(Post 500721)
Hello,
1 x 1 square electronic thing dropped down while pan was dropped. Was dangling by a wire. 2000 Blazer 4 Door 4WD Where at exactly was this dangler located ? Maybe You lost a check ball if a shift solenoid has one behind it ... http://imageshack.us/photo/my-images...ebodyview.jpg/ http://imageshack.us/photo/my-images...ebodyview.jpg/ |
Got it,,it was a shift solenoid.. and was dangling cuz the plastic part that pushes into the.. whatever it is.. broke off.
Thanks for the post onebadsuv... Now I have to figure out why I suddenly have no dash or tail lights and why headlights are so dim. Oh, and that buzzing sound in the driver side dash. All started today. Man O man, every time I turn around there is an electrical issue.. |
(Post 501382)
Thanks for the post onebadsuv... Now I have to figure out why I suddenly have no dash or tail lights and why headlights are so dim. Oh, and that buzzing sound in the driver side dash. All started today. Man O man, every time I turn around there is an electrical issue.. No problem , glad to help ... the plastic broke off where it plugs into the valve body - they get brittle with time . You can often get a good used replacement from a transmission shop for next to nothing . Check Your headlight/parking light switch and connections for the lighting issues - mine didn't "buzz" but had the same no light symptoms before I replaced it with a clean JY switch and dimmer assembly ... the contacts in these switches carry current and burn out over time and use ... I've heard relays buzz like You describe too . |
| All times are GMT -5. The time now is 04:45 AM. |
