Why won't it start?!
I have a 1995 S10, and I just can't get it to start. In the past three weeks I have replaced the following: fuel pump, fuel sending unit, fuel filter, fuel pressure regulator, distributor cap, rotor, plug wires, plugs, ignition control module, and the ignition coil. I have also replaced the alternator and the battery within the last year. I love my blazer, but I am really ready to push it into traffic. The starter engages and the engine turns, but it will not start. Any ideas?
Have you tested fuel pressure? Even with a new pump, if there is a problem with the fuel distribution internal to the engine, it can cause a no-start. Fuel pressure is the first thing to check on the CPI motors. You need 55psi or higher for the engine to properly start. If you test the pressure and it is in excess of 55psi and still no start, then monitor the pressure after you turn the key off. If it drops to zero, you have a leak somewhere in the system. With the CPI system, this is most likely either an FPR failure, or leaking internal fuel lines.
If you find that the fuel pressure is either not adequate or leaks down quickly, check out the how-to in the DIY section.
I have a 03 blazer when I turn the key to the on postion I hear it pressure up so I know i'm getting fuel.see if you can hear the same noise if not check the the fuel pump relay or any other fuses in the engine compartment. If you are getting fuel do what swartlkk says. to see if you have the right pressure. if you only get 54 or less PSI that pump fails.
bigdaddykane93
Jul 18, 2010 02:46 PM
Irish10Hockey
Nov 13, 2008 02:48 PM
