Will not lock into 4Hi but will lock into 4LO
sounds like the transfer case is going out, fairly common problem is for the truck to start having issues in 2WD (usually an ear shattering reverse clunk) and then for it to just not want to move at all. your issue is slightly different but make sure that the actuator is actually pulling the front differential all the way into lock and the transfer case all the way into gear.
Most probably has to do with the TCCM and the electrical actuator/encoder.
One of the fault codes causes it to do this "rail to rail" shifting where it has only 2HI or 4LO.
Have to look up that thread on the issue. A lot of good information about troubleshooting and the innards on the 1st gen.
Information thread:
https://blazerforum.com/forum/tech-a...-switch-29170/
And the original repair thread with the pictures of the encoder motor.
https://blazerforum.com/forum/articl...-switch-25087/
Information thread:
lukeawilliamson
01-20-2012 09:28 AM
eric.kimbrel
09-22-2009 01:59 PM
