Won't shift down
Old Sep 30, 2014 | 08:23 PM
btdawgs10's Avatar
btdawgs10 is on a distinguished road
Default Won't shift down
I have a 74 4x4 k5 blazer automatic transmission has been rebuilt about 20 years ago but with minimal miles since then it shifts up fine but wont shift down unless you manually put it in first then back into drive WHAT MIGHT B THE PROBLEM??
Old Sep 30, 2014 | 09:03 PM
Is the kick down cable (a.k.a. TV or Throttle Valve cable) connected to the carb?
Also, is the vacuum line connected to both full intake manifold vacuum source on the engine as well as the modulator on the transmission?
Old Oct 1, 2014 | 06:53 AM
btdawgs10's Avatar
I will have to check that
Old Oct 1, 2014 | 08:32 AM
If you need visual assistance, just let me know and I will snap some pictures of the areas of interest on my '74.
Old Oct 2, 2014 | 09:21 AM
btdawgs10's Avatar
Please do show me some pictures I am going to try to fix it this weekend
Old Oct 2, 2014 | 09:26 AM
I will try to remember to take some pictures when I get home from work this evening.
*EDIT* - Please find the annotated attachments below:
Attached Thumbnails Won't shift down-2014-10-02-18.13.52.jpg   Won't shift down-2014-10-02-18.15.20.jpg   Won't shift down-2014-10-02-18.15.05.jpg
Old Oct 3, 2014 | 11:07 AM
btdawgs10's Avatar
Thank you. I will try to check that out I'm not to mechanic Savvy but I will c what I can do with it
Old Oct 3, 2014 | 03:38 PM
btdawgs10's Avatar
I looked at the vacuum module and the short piece of hose after the module looks like it has a pin size hole in it could this b the problem
Digitized
Jan 12, 2014 12:07 PM
andrewrj
May 6, 2012 07:28 PM
wallacereid
25
Mar 10, 2012 10:07 AM
nicocide
Jul 13, 2010 07:57 PM
DANNO424
Mar 20, 2009 07:34 AM
