wont start
Old Feb 13, 2008 | 07:49 PM
P_F_T's Avatar
P_F_T is an unknown quantity at this point
Default wont start
well my car is a 1998 blazer 4.3l. The car car turns over but never starts, There is spark at the coil and there is fuel at the rails although it is low pressure. i had a simaler problem last month but it was the spark plugs that were bad. once i changed those it ran fine untill now. i am completely stumped and hope someone can head me in the right direction.
Old Feb 13, 2008 | 08:03 PM
Default RE: wont start
If you even think there is a fuel supply issue, you need to actually test the fuel pressure. You need atleast 55PSI for the engine to start and run properly.
Old Feb 13, 2008 | 08:04 PM
c0a8l0v6i8n9's Avatar
c0a8l0v6i8n9 is an unknown quantity at this point
If the fuel pressure is low its not going to start
Old Feb 15, 2008 | 01:50 PM
P_F_T's Avatar
well yesterday morning it started i still think i have a fuel pressure problem though but i have another issue now. I took the distributer cap off to see if water was somehow getting in there since i seemed to only have problems after a heavy rain or snow. I broke one of the mounts on the cap taking it off so i bought a new and put it in and connected all the plugs in the same order. The car starts but definetly sounds like 1 or more of the cylenders arent firing and i have a check engine light. anyone have any insight as to what i messed up?
Old Feb 15, 2008 | 02:33 PM
rriddle3's Avatar
If the engine light didn't come on until after you worked on it, then it could be that one of the wires was not pushed back on all the way. Double check the wire connections.
Old Feb 15, 2008 | 02:42 PM
P_F_T's Avatar
ive checked all the wires, even took it apart again to see if i did something wrong and i still have the same issue
Old Feb 15, 2008 | 02:46 PM
rriddle3's Avatar
I would disconnect one wire at a time and see if the sound or performance changes. The one that does not cause a change is the one that is misfiring. We can go from that point.
Old Feb 15, 2008 | 03:30 PM
P_F_T's Avatar
i got it newbie mistake lol 2 of the plugs were mixed up. it runs fine now, check engine light is still on though. When i did all the spark plugs the engine light stayed on for a day and went away on its own, so im hoping its the same situation.
Old Feb 15, 2008 | 03:44 PM
rriddle3's Avatar
After the PCM senses the required #'s of 'drive cycles' it should clear it.
JimmyBlaze541
May 2, 2013 10:00 AM
bobby099
15
Nov 7, 2012 07:29 PM
FreeTime
Sep 8, 2012 01:38 AM
slammed95blazer
Oct 27, 2010 07:24 AM
jetsmy
Aug 1, 2008 10:10 PM
