Won't Start when hot
Old Dec 29, 2007 | 01:43 PM
dmc919's Avatar
dmc919 is an unknown quantity at this point
Default Won't Start when hot
I just bought a 94 s10 blazer with the 4.3. My problem is when it gets hot that it wont startup. Turns over just fine and i hear it stumble a little like it wants to start. When it's cold i dont have a problem. also if i put some either in it when it's hot then it'll start right up.
Old Dec 29, 2007 | 07:52 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: Won't Start when hot
Ignition module??? under the dist rotor, Just a thought,, I know that used to be common in older cars....
Old Dec 30, 2007 | 01:59 AM
Chevy Lover's Avatar
^^ Ignition module would be my guess also.
Old Dec 30, 2007 | 08:50 AM
I too would suspect the ICM.
Not sure where it is located on the 1st gen motors, but on the 96+ motors, it is located near the passenger side valve cover and has a heat sink on it. Most common with these is for the thermal paste to dry out, prohibiting the transfer of heat to the heat sink, overheating the unit.
Old Dec 30, 2007 | 11:09 AM
dmc919's Avatar
how can i check to see if it's working?
Mandrwj
Apr 10, 2011 07:32 PM
rickrob16
Jul 10, 2010 05:16 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
xAnarChisTx
Jun 4, 2008 10:49 AM
kerk45
Engine & Internal
Sep 21, 2005 03:04 AM
