Worn Speedometer Cable?
Old Dec 27, 2010 | 10:48 AM
mscollins47's Avatar
mscollins47 is on a distinguished road
Default Worn Speedometer Cable?
what are the symptoms of a speedo cable that is on its way out? I think thats what is happening....lots of buzzing/intermittent when driving, gets worse when using accelerator, usually stops when stopped or slowing down. My old cavalier had same thing and I was told it was a speedometer cable. No issues with actual meter though.
Old Dec 27, 2010 | 02:53 PM
What are you driving?
Old Dec 28, 2010 | 07:14 PM
2002 blazer, 2 door, 6 cyl
Old Dec 28, 2010 | 08:15 PM
You do not have a speedometer cable. The speedometer uses an electronic sensor in the back of the transmission (2wd) or transfer case (4wd).
Your problem is likely the cruise and/or throttle cable resting on the PCV hose and transmitting the noise from the PCV valve in through the throttle cable.
kmartin
Oct 3, 2014 09:54 PM
Straka88
Dec 6, 2010 08:07 AM
4x4VegasDan
Nov 27, 2009 08:02 PM
rogggg1020
Oct 19, 2008 10:47 AM
SDimeBlazerlady
Tires and Wheels
Oct 21, 2006 01:06 AM
