would like to convert to 96 and newer tbi
Old Sep 22, 2008 | 10:02 PM
65longroof's Avatar
65longroof is an unknown quantity at this point
Default would like to convert to 96 and newer tbi
I have a 95 blazer with the CPI set-up on it. I know the injection unit has been replaced once and at $300 a shot I don't want to replace it again. What would be involved in converting to the 96 and up TBI set-up? I know the upper and lower intake, throtle body, engine computer and harness but what else?
Thanks,
Paul
Old Sep 22, 2008 | 10:12 PM
Default RE: would like to convert to 96 and newer tbi
A lot more than what it is worth. The 96+ is an SCFI motor which has sequential injection with the six injectors vs. a single batch fired injector that the CPI motor has. The problem is that you would have to swap out the PCM and work out the rest of the electronics in the truck... And then you would have to swap over the whole top end of your motor, heads and all if I remember correctly.
Old Sep 22, 2008 | 10:21 PM
65longroof's Avatar
So I am better off dealing with the CPI set-up or is there another option?
Old Sep 22, 2008 | 10:39 PM
The best thing for the CPI motors is to upgrade the FPR with the kit from Lindertech.com and then use Chevron Techron Fuel System Treatment plus at every oil change to clean the injectors.
Daytimenoo
Apr 4, 2012 11:36 PM
deathman
Aug 14, 2011 11:25 PM
zakm0n
Jan 10, 2011 11:42 AM
maverik78
Performance & Brainstorming
Apr 11, 2010 10:05 PM
ZLover4Life
46
Dec 22, 2008 01:01 AM
