1986 K5 4x4 Blazer - Starter help
Old May 18, 2009 | 03:21 AM
Steeltoe623's Avatar
Steeltoe623 is on a distinguished road
Default 1986 K5 4x4 Blazer - Starter help
I have a 1986 K5 4x4 Blazer 305. Just a little while ago I was out running some errands and my truck was running excellent. I had stopped somewhere and when I tried to start the vehicle the turn-over sounded a bit weird, as if the starter wasn't catching correctly. I tried again and it was making the same sound but eventually it started. I then drove home immediately. When I got home I turned the vehicle off and tried starting it again. It made the same noise again and so I let it sit for a little while. I then went out to start it again but this time the vehicle made this high pitched grinding/scraping sound but it would turn over. I had my friend come out and attempt to start the vehicle while I looked under the vehicle area where the starter was. It sounded as if the starter was making that noise. The thing is is that I had just replaced the starter 5-6 months ago so I have no idea why it would be doing this. Could it be the starter or could it be something completely the opposite? Any help would be greatly appreciated.
Thanks!
Old May 18, 2009 | 06:45 AM
oisinirish's Avatar
Did you check to make sure the starter is still tight to the block? If there was some gunk on the block where the face of the starter mates up the bolts will never stay tight. May try tapping the solenoid a few times and see if that helps. It sounds like the drive gear on the starter is making poor connection with the flywheel.
Old May 18, 2009 | 09:58 AM
Will do. Thanks for the info.
*Just noticed we basically have the same vehicle.
Old May 18, 2009 | 11:02 AM
oisinirish's Avatar
Get some pics up there!
While your down there make sure your electrical connections are good and solid.
May have to take it and get it bench tested if all else fails.
Old May 18, 2009 | 12:50 PM
Sure sounds like a starter issue. I would drop it out and have a look at it. Maybe bench test it to make sure that the solenoid is kicking the bendix out for proper engagement into the flywheel/flexplate.
Old May 19, 2009 | 05:02 AM
I got it out and the nose cone was cracked in half. I took it back to Autozone where they gave me a new one. I put that one in and it fired up no problem. Thanks you guys for the help.
Old May 19, 2009 | 07:42 AM
oisinirish's Avatar
Good deal.
Old May 19, 2009 | 11:43 AM
That would do it! Glad you got it fixed!!
jdmmario
Oct 25, 2014 06:25 PM
auto-bot
20
Oct 27, 2011 06:54 PM
Shawn F.
Jul 22, 2009 08:35 PM
Steeltoe623
May 18, 2009 06:48 AM
