1987 k5 question
whats the biggest tire i can fit with a 6 inch suspension lift? i'm thinking 35 14.50 15. anyone running bigger without the tires hitting? i'm not going to be doing extreme flexing.
I know you can run 35's with a 4" lift, with a 6 I would assume a little bit more. I'm just guessing though.
I believe you can fit 38s with a 6 inch
38s on a 6 inch are really pushing it. i ran 38s on 3 trucks with 6inch lifts. its possible to drive it on the road without it rubbing but any big bumps or any turns over like 2 mph they rub.
can always slap a 2 inch body lift on |
35 x 12.5 easily on a 6" lift. They rub on a 4" even with trimming.
35/12.50/15 on a 6inch lift
http://i2.photobucket.com/albums/y14...ownedit1-3.jpg 38 12 50s on stock rims, again 6 inch lift http://i2.photobucket.com/albums/y14...terlift2-5.jpg as you can see you can technically drive it. i drove it like 5 miles to work like that rubbed a few times while turning and hitting hard bumps |
thanks for the pics. 35x12.50's is what i have now on 15x10 wheels. i'm putting 37 13.50's on 15x14 wheels. hope it doesn't hit but if it does i guess i'll have to jack it up a little higher
