1989 5.7 k5blazer problem
Old Mar 19, 2012 | 09:48 PM
K5blazer420's Avatar
K5blazer420 is on a distinguished road
Default 1989 5.7 k5blazer problem
I did the wire trick and the only code that comes up is 12...It idles fine but whenever i give it gas it boggs down... sometimes dies
any helpful tips to solve this problem
5.7 1989 k5 blazer
already changed the injectors,dis.cap,router,pcv valve,air idle control sensor,and fuel pump
Old Mar 20, 2012 | 02:17 PM
1987k5350's Avatar
1987k5350 is on a distinguished road
I had the same issue not to long ago, ended up changing the throttle control modd, fixed the bogging issue. now im haven a problem with the truck stalling when in gear, i have an 87 with a 5.7
Old Mar 21, 2012 | 11:50 PM
abig84's Avatar
you can check the egr valve. ive seen them go bad where they open wide open at idle and cause a major vacuum leak and cause the engine to die out at idle. probably gonna need to people, the last truck i worked on it didnt do it at idle, had to put it in gear and give it a hair of gas
Old Mar 31, 2012 | 02:48 PM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
Have you replaced the fuel filter or the coolant temperature sensor? Common fixes for a problem like yours.
Old Apr 3, 2012 | 04:11 AM
i changed the fuel filter and coolant temp. sensor and the same problem is happening....
anymore ideas..ill try about anything
Old Apr 3, 2012 | 05:54 AM
Fuel pressure in spec (9-11psi)?
MAP sensor reading properly?
TPS sensor reading properly (~0.5V at closed throttle & smooth transition up to ~4.5V at wide open throttle)?
EGR valve operating properly (as previously mentioned)?
Old Apr 6, 2012 | 09:32 PM
Well i got the truck running great...but whenever im in gear and give it gas it has no power the truck barely moves even though it runs great
jayblazer
Apr 11, 2011 12:44 PM
jag2791
Nov 5, 2009 06:49 PM
bigt
Feb 2, 2007 10:17 AM
bruce.mcvicker
Apr 30, 2006 12:06 PM
89Blazze
Oct 31, 2005 09:50 AM
