1990 K5 GM Codes in Glovebox Question
Old Mar 24, 2011 | 08:08 PM
educky's Avatar
educky is on a distinguished road
Default 1990 K5 GM Codes in Glovebox Question
I'm Guessing that G80 in a 1990 K5 does not equal locker like the newer trucks right?
Old Mar 24, 2011 | 08:09 PM
Sure does.
Old Mar 24, 2011 | 08:13 PM
educky's Avatar
Really? I was skeptical....
How do I know for sure if its there or previous owners took it out?
Im about to pull the cover off, is there a way to actually see the difference? or something else I can do?
Old Mar 24, 2011 | 08:20 PM
If you only see 4 spider gears in the center of the diff and not much else, it's an open diff. If you see weights, clutches, etc, then it's a G80.
Old Mar 24, 2011 | 10:16 PM
abig84's Avatar
or a bunch of broken parts and teeth missing off the little sliding pieces in there then you have a g80
i swear i dont think i have ever opened a axle on a k5 where that thing wasnt stripped up or broken.
Old Mar 25, 2011 | 11:01 PM
educky's Avatar
Whew, forgot what the diff smell does to a garage... took the cover off, this is what i saw... no grenade went off in there...
G80 or other? LSD mebbie? Im new at this...
http://forwarding.dyndns.org:8082/k5.../WP_000108.jpg
Old Mar 26, 2011 | 07:18 AM
That's a G80.
Old Mar 26, 2011 | 09:25 AM
educky's Avatar
So Im guessing based on the other poster, that the G80 isnt as great as I thought... I dont plan on rock crawling in this thing just light offroading... so I hope it does ok and doesnt fall apart.
Thx for the info BTW!
Old Mar 26, 2011 | 10:07 PM
educky's Avatar
Also all the documentation points to my year being a posi, is that what a posi looks like, or thats definatley a G80 locker... Im not trying to argue, just wonder if someone put that in there after the factory or something... I have no history of my vehicle.
Old Mar 27, 2011 | 07:17 AM
That is definitely a G80. A posi would have a bunch of springs in the middle. The picture you posted shows the governor assembly which is what triggers the axle lock when wheel slip is detected. Just below that is the weight which disables the locking action over ~30mph.
The Eaton G80 differential isn't all that bad so long as you stay reasonable and understand how it operates. Given that it locks up on detection of wheel spin, you want to give it a chance to lock in before you put a lot of power to it. If you are in the gas hard and one wheel starts to spin, especially with larger tires, the locking action will shock the diff and bad things can happen. Then there is the point to be made that there are clutches inside that once they wear out, you will essentially have an open differential.
Some have experienced spectacular destruction of their G80 while others have had very good luck with them. I am in the latter category. We have had G80's in the last few farm trucks on my father's farm and these trucks have been royally abused with no diff failures.
