1991 K1500 Blazer No Heat
My 1991 Chevy K1500 Blazer (5.7L) has no heat, or at best luke warm. The coolant is full, I have replaced the thermostat, heater core, radiator, engine temp sensor, and the fan clutch. The engine temp stays just above the 100 mark about 120-125 or so. The blower motor blows on all speeds as it should, and I can change from defrost to floor, or blend in between and they all work as they should, but the heat stays luke warm at best. What concerns me is the engine temp does not get any higher than 120-125.
Does anyone know what the problem might be?
Thanks.
Thanks.
Let me clarify myself, the Blazer starts as normal, and warms up as normal to that point…120-125 temp range. No bypasses. Everything is stock. The Blazer has a little over 80k original miles. Everything else operates fine. This problem just started one day out of the blue and I have not been able to figure it out since.
camaro91boy
Feb 8, 2009 11:37 PM
chevyman09
Dec 7, 2008 07:58 AM
izaquad
Nov 26, 2007 08:19 PM
