1991 K1500 Blazer No Heat
Old Nov 24, 2009 | 02:57 PM
nash_686's Avatar
nash_686 is on a distinguished road
Default 1991 K1500 Blazer No Heat
My 1991 Chevy K1500 Blazer (5.7L) has no heat, or at best luke warm. The coolant is full, I have replaced the thermostat, heater core, radiator, engine temp sensor, and the fan clutch. The engine temp stays just above the 100 mark about 120-125 or so. The blower motor blows on all speeds as it should, and I can change from defrost to floor, or blend in between and they all work as they should, but the heat stays luke warm at best. What concerns me is the engine temp does not get any higher than 120-125.
Does anyone know what the problem might be?
Thanks.
Old Nov 24, 2009 | 03:07 PM
That would not be warming up normally. Warming up normally would be engine temps in the 200-210F range for a 195F thermostat. Are there any lines bypassing the thermostat?
Old Nov 24, 2009 | 08:03 PM
nash_686's Avatar
Let me clarify myself, the Blazer starts as normal, and warms up as normal to that point…120-125 temp range. No bypasses. Everything is stock. The Blazer has a little over 80k original miles. Everything else operates fine. This problem just started one day out of the blue and I have not been able to figure it out since.
Old Nov 24, 2009 | 09:46 PM
oisinirish's Avatar
Is it possible that you got 2 bad thermostats in a row?
Old Nov 24, 2009 | 10:40 PM
nash_686's Avatar
I guess anything is possible. I am going to check it again.
Old Nov 24, 2009 | 11:24 PM
abig84's Avatar
yeah 120 is not normal operating temperature. i had a 160 thermostat in a s10 and the heat sucked on that thing.
Old Nov 25, 2009 | 06:43 AM
The only thing that controls the temperature in the engine is the thermostat. Something is not correct with the one you installed.
camaro91boy
Feb 8, 2009 11:37 PM
chevyman09
Dec 7, 2008 07:58 AM
Blaze GM4
Feb 18, 2008 06:56 PM
jigger1515
Dec 18, 2007 04:41 AM
izaquad
Nov 26, 2007 08:19 PM
