1991 k5 blazer rear differential problems
Old Jan 26, 2013 | 11:15 AM
Grizzle21309's Avatar
Grizzle21309 is on a distinguished road
Oh and the rims that we have are 6 bolt
Old Jan 26, 2013 | 12:24 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
If you cant find a 6 bolt rearend you can swap your axles out with a 5 bolt pretty easily but the 6 bolt rear end should be an easy find.
Old Jan 27, 2013 | 12:26 AM
Mossyoaksilverado's Avatar
Mossyoaksilverado is on a distinguished road
You should easily be able to find a 10bolt rear differential laying around somewhere. I wouldnt pay more than 100 to 150 at max. Dont let them know how badly you need it and youll get a good deal. I can go down the street right now and get a 3/4 ton running gear on wheels with driveshafts, leaf springs, th400 w/ case for under $500.... and thats pretty common.
Old Jan 27, 2013 | 12:30 AM
My rear driveshaft fell out and am trying to figure out what it is I need to replace. Driveshaft is fine, u-joints fine, my bolt broke and the guy at advance said it would be the pinion gears as the pinion will rock side to side when moved by hand and not up and down.....not sure where to go from here he said it would be a cone or cup but idk how to find out wich one, or what else would have to be replaced.
I have a couple questions about what you have said here. You say the driveshaft is fine, u-joints are fine, but your driveshaft fell out? So did the straps on the pinion yoke break? Also, if you can move the pinion side to side, is there any fluid leaking from it? There is a seal there, if you have movement on your pinion then you have a leak. Be sure the large nut in the center of that pinion is tight too.
Old Jan 28, 2013 | 07:53 AM
I know that the nut is sitting in my house and the pinion is still sitting in the truck. Its not leaking now but I wasn't the one who was driving when it fell out. He said something like the bolt that holds the driveshaft up in the back broke. I wish I had something to take pictures with, but I don't.
Old Jan 28, 2013 | 10:42 AM
70-K5's Avatar
70-K5 is on a distinguished road
Originally Posted by 1sttimejimmyowner
Apology for blunt reply but seriously I think 70-K5 is way off on the price of usd differentials.Maybe $50-$100 on the carrier assembly but for complete around $150-$300 depending on the gear ratio.
No worries.... Parts like axles can vary from state to state... In Oregon nobody want's 3.73's, with the hills we have 4.10 and 4.56 are minimum if you're running anything other than stock size tires.
I traded my to bolt in great condition to a local 4x4 parts store for an Extreme high lift jack... I thought I got a great deal... Otherwise it was worth scrap value.
To the OP, what are the pieces that are broken? i'm still confused with what actually happened.
Check out the members map from another board I'm on and let me know if any member is near you. Maybe they can help sourcing a part....
chevyk5blazer.com
Drew4711
Oct 6, 2012 12:47 PM
Aquarian Devil
Apr 11, 2012 12:50 PM
k9scats
Mar 26, 2012 01:06 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
sampsond135
Oct 7, 2006 11:24 AM
