1994 headlight diagram
Old Dec 11, 2007 | 04:35 PM
quebecoffroad's Avatar
quebecoffroad is an unknown quantity at this point
Default 1994 headlight diagram
I have a big problem on the headlight not working, high and daylight are working.
I have changed the switch, nogo, and jumped the high-low switch and still no Volt on the headlight.
anyone have a tip, the wires look good but can't find where the beige wire is going before going the the headlight.
Old Dec 12, 2007 | 12:59 AM
Chevy Lover's Avatar
Default RE: 1994 headlight diagram
The tan (or beige) wire should come from the dimmer switch to power the low beam headlights.
Try jumping the tan wire direct to battery positive. If the lights don't come on, use a test light to check the headlight connector for power and ground.
I think you have either 2 burned out low beam headlights or a faulty dimmer switch.
Sorry, you said you replaced the switch. Was that the dimmer switch or the headlight switch?
Old Dec 12, 2007 | 07:20 PM
I have replaced the light switch, and jumped on the High-low switch, I did'nt know the dimmer has something to do with it.
You are talking about the dimmer for the dash light?
Old Dec 13, 2007 | 12:48 AM
The dimmer switch that I refer to changes your lights from low to high beam, I guess that's what you call the high-low switch.
So my next question is how did you jump the switch, did you apply 12 volts to the tan wire?
Old Dec 19, 2007 | 06:55 PM
Yes I did, and It did not work, but I have taken the tan wire and jumped it to the light directly, and it worked, so I presume that the tan wire is broken somewhere....
Old Dec 19, 2007 | 07:12 PM
Good to see that you're making progress.
86FIFI
Sep 26, 2011 09:12 PM
TZFBird
Jun 2, 2011 09:14 AM
raptorman
19
Jan 14, 2010 10:21 PM
camaroz
15
Aug 26, 2008 07:44 PM
chris
Dec 6, 2004 12:47 AM
