350 Won't Start
Old Dec 9, 2008 | 10:22 AM
LrsUlrich's Avatar
LrsUlrich is an unknown quantity at this point
Default 350 Won't Start
I have an '88 K-5 Blazer with a 350 TBI. I've been having a lot of fuel pump problems over the past year. My first pump went so I replaced it, but while I was doing maintenance on the second pump, it stopped working. Now I'm on my third pump and it works fine, my problem is that the fuel isn't getting to the engine. When the engine is primed it runs fine, but no fuelmakes it up so it stalls out.The fuel makes it to the filter then seems to disappear. The lines have been blown clean and there is no visible leak. Any one got any ideas?
Old Dec 9, 2008 | 12:09 PM
Default RE: 350 Won't Start
Have you ensured that there are no kinks in the line? Have you removed the connection at the back of the throttle body and checked the fuel pressure there with an inline gauge connector?
Old Dec 9, 2008 | 02:18 PM
LrsUlrich's Avatar
Not yet. I'm in the process of trying to get a gauge since I don't personally own one. And there are no kinks that I can find in the line.
Old Dec 9, 2008 | 02:30 PM
rriddle3's Avatar
I'm going to move this over to 'Full Size Tech'.
Old Dec 9, 2008 | 02:37 PM
Good catch Rich! I completely missed that...[&o]
Old Dec 9, 2008 | 03:09 PM
LrsUlrich's Avatar
Until I can get a hold of a pressure gauge, is there anything else you can suggest? I've run out of ideas.
Old Dec 9, 2008 | 04:26 PM
Default RE: 350 Wont Start
So when you try to start the truck, you cannot see fuel spraying out of the injectors in the throttle body?
The only other thing that I had thought of is a leaking TBI base gasket, but if you cannot see any fuel coming out of the injectors, then it probably is not that.
tech180
Feb 2, 2013 10:23 AM
princered72
Sep 13, 2011 10:36 AM
Dark Rider
Aug 8, 2010 11:57 PM
1BSBAKER
Aug 11, 2009 10:54 AM
Irish10Hockey
Nov 13, 2008 02:48 PM
