4 speed conversion in 84 k10
Old Jan 12, 2008 | 06:16 PM
84k10blazer355's Avatar
84k10blazer355 is an unknown quantity at this point
Default 4 speed conversion in 84 k10
i was able to find a donor truck for my 4 speed conversion. its a 78 k truck. my question is: are the trans tunnels in a 4 speed blazer the same as a 4 speed blazer? both 78's? i figure they are the same and could be wleded in with no problem but will i run into any problems? for example- the trans hump is much tall er or wider than a blazer? also i figure id have to shorten the drive shaft cuz its a long wheel base and i have a 700r4. if anyone has done this before or ran into a similar situation please let me knoe before i buy the truck for 400 bux!!
Old Jan 12, 2008 | 08:35 PM
Default RE: 4 speed conversion in 84 k10
You can just bump the original thread on this subject... That is preferable as opposed to double posting the same question or a slight variation...
Pipewrench Dale
Nov 10, 2014 06:16 PM
Bobcat13
Nov 10, 2013 06:03 PM
jdub9000
Jul 22, 2013 07:58 AM
84k10blazer355
Jan 5, 2008 09:12 PM
