4x4 not engaging
Could be a faulty front axle actuator. The early version is an electro-magnet and is, unfortunately, known for this. GM released a revised electric motor driven actuator to cure the problem, but it takes some wiring to put it in. I posted information about this around here somewhere.
Are you getting power to the front axle actuator? Did you put in the same style of actuator or did you install the newer update kit? The update kit requires some wiring changes, but is much more reliable.
i checked it and it has power i plugged it in to see the actuator move and it does slowly... but it takes like no pressure to push it back in. and this thing was suppose to be brand new? is that a faulty actuator or is it just that the electros all do that n suck
seriosbrad
Nov 7, 2015 09:08 PM
chrisblaze
Dec 6, 2009 12:27 AM
I8URVTEC
Jul 28, 2005 06:56 PM
