76 k5 cranks and turns over but doesn't start
Old Oct 7, 2010 | 01:51 PM
2000TAHOEMAN's Avatar
2000TAHOEMAN is on a distinguished road
So i checked ignition module and it looks good, i sanded the prongs on the inside of the cap also and nothing still. I also connected the wire from the cap to the battery and still just cranks. Would a blown fuse stop it from turning on? I thought it was fuel but i opened the throats and put gas down and tried cranking but still nothing.
Old Oct 7, 2010 | 02:07 PM
tmedley's Avatar
tmedley is on a distinguished road
Check the rotor where the cap button touches the rotor, they have a tendency if not changed very often to wear a hole through and then the arc will strike the center shaft of the dizzy instead of making it's way out to the plugs.
Did you actually see a spark from the wire or just feal the shock? If it is getting fuel and spark and it was losing power you may have something mechanical happening here.
What kind of compression do you have? How many miles on this engine? Carbon build up on valves can lead to low compression and loss of power. Or just plain old wore out parts.
I would still double check with a spark tester on the wires first.
hope some of this helps.
also a coil can fail and still spark but fail to send enough energy to spark under compression. HEI coils are cheap might check that as well.
Old Oct 12, 2010 | 01:57 AM
So i checked the plugs, wires, cap and rotor, ignition module, spark, fuel and still nothing. Does anyone have any other possible solutions? Thank you
Old Oct 13, 2010 | 06:57 PM
blueblazer1982's Avatar
blueblazer1982 is on a distinguished road
Lets break it down,
your engine needs to crank over, create spark, get fuel, have compression
somehow you are not getting one of those. if its cranking over and your getting fuel , you're most likely not getting spark. on these 350s they are very simple. it can be as easy as 1 wire not getting power to your ignition coil.
did you take 12 volts to the distributor?
i would throw a new fuel pump on there too.
Old Oct 20, 2010 | 01:42 PM
I can't seem to find the problem.............im getting ready to sell it
Old Oct 20, 2010 | 05:28 PM
Having spark and having a properly timed spark can often be the difference between a vehicle that doesn't start and one that does. Have you tried changing the timing by rotating the distributor?
Old Oct 30, 2010 | 08:25 PM
Kjared2's Avatar
Kjared2 is on a distinguished road
Cool
I am no master mechanic or anything but how come no one said anything about the engine getting the proper amount of air into the Carb? Spark, Compression, Fuel, and of course air....
If the Carb isn't taking in the proper amount of air or maybe one of the Air/Fuel ratio needles isn't set properly it wont run....
He said it was starting to bog down while driving, maybe the carb is clogged and cant suck in any air....
Try to ***** the carb with carb cleaner and check the air/fuel ratio adjustments
If your getting Fuel, Spark and compression the only thing left is air....or maybe it's time for a new carb
Old Oct 30, 2010 | 08:34 PM
Good point. I have experienced a lot more timing related problems with older vehicles I have fixed than carb problems which is why I directed more attention to that area. But really, it comes down to a process of elimination and every process has to start somewhere.
Old Nov 18, 2010 | 04:08 PM
How can I find out if the truck is out of timing?
How can I find out if the truck has a bad head or motor?
Old Nov 18, 2010 | 07:19 PM
With a timing light.
With a compression tester.
