?87 k5 tbi 5.7l dies when i turn right?
the truck always starts when cold. sometimes when hot it doesnt start just turns over. if i waite a while and try again it will start. last couple of days dies when i turn right. i changed the ignition module. still have the same problem?
It only dies when you turn right? Does it do it consistently? Is there a particular speed you have to be driving at while you turn right?
I would be looking for some wiring that is grounding out whenever you turn right... |
YES!!!! i wasn't the only one to have this happen.
sorry matthp, but this drove me up the wall when it was happening to my '90 'Burb-and it only happened when i made a qiuck right hander (coming off an off ramp, onto the road too quickly, simply swerving to hard to avoid something). my truck was blowing the fuse for the pump. i traced all the wires for the pump, from the pump back to the fuse panel-i even took the fuse block apart @ the firewall-still couldn't find the short/rub. so i just kept a BIG box of fuses in the console. i got so good @ changing the fuse, i could swap it from the driver's seat without even looking (it went on for a looooong time!). sorry i couldn't help you, but maybe you'll have better luck than i did. |
Different body style and all, but I would look at the wiring on the driver side frame rail where it passes under the body at the firewall. We had a similar issue on my Dad's '94 K2500 pickup. The body would sag enough on right handers to squash the wiring and ground out. It wasn't enough to blow the fuse, but it was enough to disrupt the fuel flow.
Originally Posted by swartlkk
(Post 264407)
i checked under there on my 'Burb, first thing. seems the body mounts/floor were about the only part of the truck that wasn't rotted & sagging, hahahaha. wish i had found the problem, it probabaly cost me 15 to 20 bucks in fuses for the rest of the life of that truck. |
Yes, I was talking about my dad's '94 K2500.
yeah, sorry about that. i kinda realized that's what you were probably talking about AFTER i posted. it's ok everybody, i'm "the tool of the day".
