89 rim question
Old Dec 12, 2014 | 01:36 PM
Brianjaxon7's Avatar
Brianjaxon7 is on a distinguished road
Default 89 rim question
Will a 1989 Chevy k5 blazer fit stock 17 inch rims off a 2005 GMC Sierra 1500?
Old Dec 12, 2014 | 01:56 PM
The 6 on 5.5" bolt circle stud spacing is the same from the squares to the newer trucks, but the hub diameter on the newer rims is smaller than what is required for a square. Also, the back spacing on the rims is considerably more than the original rims used on the square body trucks. It can be done, but you will need to have spacers made to correct the offset so you don't run into the springs while steering.
Old Dec 13, 2014 | 11:02 AM
abig84's Avatar
yeah i tried to do this years ago with a late 90s suburban rims, the backs bolted up to my old suburban but when i tried to put the fronts on they tightened into the tie rod. i believe those were 16s with 17s you MAY get really lucky and clear the tie rods,
but the backspacing sucked, the tires were tucked under the truck, basically looked like one of those trucks you see driving around that drives on the railroad tracks
evuldrporkchop
Mar 4, 2013 01:20 AM
kmt
Jun 24, 2006 12:34 PM
badblazer
Suspension Tech
14
Jun 23, 2006 08:11 AM
Bgray
Tires and Wheels
Mar 21, 2006 11:54 PM
2001blazer
Mar 1, 2006 11:07 PM
