92 k5 blazer "chugging" issue
Old Apr 4, 2012 | 01:37 AM
chriskifer86's Avatar
chriskifer86 is on a distinguished road
Default 92 k5 blazer "chugging" issue
I have a 92 fullsize blazer that when at low rpm or when i let off the pedal tends to "chug". It doesnt stall, but the rpms sometimes dropps to zero and jumps back up. I have replaced spark plugs, wires, cap and rotor, coil, ICM, IAC, and TPS. Its not as often, but its still happening... Anyone have any suggestions?
Thanks
Old Apr 8, 2012 | 02:20 PM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
Have you replaced the coolant temperature sensor? If you smell the fumes coming out of the tailpipe while the truck is running, does it smell a bit like gas?
Old Apr 8, 2012 | 04:22 PM
Yes it is running rich, would the coolant temp sensor cause that issue? If so how can I tell if its bad?
I also pulled the egr valve this morning and found out I'm getting blow-by when the valve is closed, considering replacing it too just to be safe.
Old Apr 11, 2012 | 08:46 PM
The coolant temp sensor WOULD cause that issue. When it malfunctions, it tells the computer to dump in an extreme amount of fuel into the engine. I would replace it anyway as preventative maintenance as they fail frequently and can cause all sorts of odd problems. I would also replace the EGR valve just to rule that out.
Old Apr 14, 2012 | 12:00 PM
Thanks, I will do that. I'll keep u posted on how its running.
Old Apr 21, 2012 | 08:58 PM
Ok, sorrry its taken so long to reply. Since the last time I was on here, I have replaced the coolant temp sensor, egr valve, and intake gasket. The problem I had is gone, and my Blazer is running great! Thanks for the help!
Old Apr 23, 2012 | 11:35 PM
Glad to have helped.
volleyballin86
May 11, 2012 09:52 AM
Stoyka
Feb 15, 2012 01:04 AM
rednose
Feb 25, 2009 04:56 AM
RanD7573
Jan 24, 2009 08:19 PM
schnarr
Aug 25, 2008 11:37 AM
