93 K5 not locking in
Old Dec 27, 2012 | 04:07 PM
5lumsdens's Avatar
5lumsdens is on a distinguished road
Newbie here. I can feel the front grab when I put it in 4L or 4H. When I tested it in 4L on the street in front of my house it runs through the gears quickly and tops out. When I get off in the sand (to test it out) the fron is not pulling. I hear no grinding at all. Any ideas?
Update. Check the gear oil and it is fine. Found that the actuator was bad so replaced it. Still not locking in. The light on the floorboard is still not coming on either. Any suggestions?
Last edited by rriddle3; Dec 29, 2012 at 01:17 AM. Reason: Combining consecutive posts
Old Dec 28, 2012 | 07:06 PM
richphotos's Avatar
I know nothing about these things, is the 4wd vac assist? if so, Check for a vac leak somewhere.
Old Dec 28, 2012 | 09:51 PM
xgiovannix12's Avatar
No richie HE either has manual locking hubs OR automatic locking hubs. And a floor shift 4x4 system.
Put either 4 lo or hi IN and try to turn the driveshaft. If she spins the transfer case is not locked into range. IF it does lock Id check the hubs.
Old Dec 28, 2012 | 11:46 PM
richphotos's Avatar
Thank you sir. I was not sure at all on this situation if they were vac assisted, I guess only s10 blazers only have this terrible setup.
Old Dec 29, 2012 | 07:36 AM
The 92+ full size IFS Blazer (note the lack of K5 in that description) has a passenger side axle disconnect similar to the s-series,with the exception of how it is actuated; the full size IFS trucks were electronically actuated at the front axle.
The original setup was an electro-magnet or thermal unit that had a failure rate that rivaled the vacuum setup in the s-series. GM later revised the setup to a stepper motor drive that was much more reliable. I have posted the conversion information in past threads as a search for "magnetic+stepper+actuator" with an author of "swartlkk" should turn up. Use the Advanced Search tool and enter those terms in with the plus sign, and but without the quotes.
Is the actuator getting power? When in 4HI, with the passenger front off the ground, can you spin the wheel? If so and nothing else is spinning, then the front axle is not locking. If it spins & the front drive shaft does as well, then the front axle is locked, but the transfer case is not.
Let us know the outcome of those tests and we will go from there.
*EDIT* - CLICK HERE for the post/thread I was talking about.
Old Dec 30, 2012 | 05:19 PM
5lumsdens's Avatar
Ok, The actuator had a crack in the case and the circuit board was fried. Replaced the actuator and still no 4x4. Racking my brain to figure this out. Anyways we were heading to a buddy's camp to do a little mudding and while at Walmart getting beer (I mean groceries) I checked the 4x4 fuse and BAM, It was blown. fixed and 4 wheel is working again.
Old Dec 30, 2012 | 05:23 PM
The board being fried likely was the cause of the blown fuse. Glad you got it fixed up!
Galen
Aug 17, 2010 12:24 AM
98bravadaSmartTrack
May 28, 2010 07:36 PM
rippert1
Jan 20, 2010 06:01 AM
tom09
Sep 10, 2009 10:30 PM
myronhntr80
Dec 7, 2006 02:06 AM
