94 Blazer. water pump Bypass hose
Old Mar 31, 2010 | 09:28 AM
Ehracing67's Avatar
Ehracing67 is on a distinguished road
Back from the sea and wanting to finish what i started.
2 yrs ago I took the 350 out of my 94 fullsize and had it overhauled. since then I've been deployed, Just got back and wanting to finish it.
The only problem is the small hose from the top of the water pump. Where does it go? I took photos of everything before I left, but not this area. Anyone know?
water pump
Old Mar 31, 2010 | 09:55 AM
In combination with the other hose connection on the intake manifold, these should go to your heater core.
Old Mar 31, 2010 | 09:59 AM
Ehracing67's Avatar
Thats what i thought, but the heater hose goes to the rear of the manifold and there is no open port or a tee elsewhere towards front of manifold
Old Mar 31, 2010 | 10:01 AM
You should have more than one heater core hose... One should be supplied with pressurized water/coolant from the pump while the other flows back into the intake manifold.
Old Mar 31, 2010 | 10:15 AM
Ehracing67's Avatar
yep. the other hose goes to the radiator from the core.
The rear hose is the pipe/hose into the quick fitting at the back of manifold.
So both heater hoses are accounted for. Just this little hose is being the rebel.
You know, the sub is easier to work on then this.
Old Mar 31, 2010 | 10:24 AM
That's different.. But if that is the case, then you can plug that hole.
Old Mar 31, 2010 | 10:30 AM
Ehracing67's Avatar
Ok, well this is turning out to be an easy fix. This hose never went to the blazer. This is off my daughters jeep. Your're right the lack of pressure from the pump threw me off, but the pressure is from the manifold. Reason for the high pressure hose and pipe fitting. So I just need to put the plug back in.
Thanks I guess thats why nothing showed up in the photos.... Nothing there.
bigdaddykane93
Oct 23, 2012 11:26 AM
gomfrddy
Sep 3, 2011 05:44 PM
scorpionmotorsportsLV
Engine & Internal
Apr 9, 2009 11:19 AM
rob1621
Apr 3, 2008 08:55 PM
