After market fuel gauge
Old Jul 18, 2010 | 06:40 PM
BAGnDRAG-K5's Avatar
BAGnDRAG-K5 is on a distinguished road
Default After market fuel gauge
I am installing an aftermarket gauge set up. I will be building the dash bezel out of fiberglass. My main concern is the fuel gauge. If you have ever owned an older Chevy truck you know about their more than common issue with the bouncing needle. In my experience this is generally caused by a bad ground and sometimes a bad sender. I plan on running a new wire to the sender. I was just wanting to get your opinions on whether I should cut an access panel in the floor over the sender or is dropping the tank a smarter solution? I would like to build a nice panel and seam it in to match the existing floor panel. Thanks in advance to all who respond.
This panel would be wall to wall to allow access the air tanks and compressors. These components will be mounted to the frame. Of course this panel will allow ease of access but I don't want added noises or fumes in the cab of the truck.
TrailBlazer
Jun 14, 2011 07:20 PM
rroeder96
Aug 12, 2010 02:25 PM
if6was9
Mar 16, 2008 09:38 PM
nnnon632
Oct 22, 2007 01:34 PM
chevyrocksu
Headers, Intake, & Exhaust
Nov 25, 2006 03:29 PM
