that aint supposed to happen
Old Oct 30, 2011 | 08:13 PM
ericthughes's Avatar
ericthughes is on a distinguished road
Default that aint supposed to happen
hey then i grab my tie rod you can twist the whole thing and both ends move that aint right right .do i need to replace the adjustable connecting rod too?man is this dangerous to drive if i can just move my whole tie rod just by twisting the whole bar
Old Oct 30, 2011 | 08:44 PM
pettyfog's Avatar
??? What is it exactly that you think moves too much? I would hope you twist one end the other follows. The ends {ball in socket} can rotate about 35 deg each way from center, IIRC
Old Oct 30, 2011 | 11:01 PM
AJBert's Avatar
I'm a bit confused myself. How much resistance is there? Does it move with just the force of gravity or do you need to torque on it with a pipe wrench?
Tie rods are designed to rotate and flew. Too easy is not good, too tight is not good, either. You shouldn't be able to move them by hand but you shouldn't need to double wrench a pipe wrench either.
Old Oct 30, 2011 | 11:06 PM
pettyfog's Avatar
I disagree. They shouldnt flop around but if you cant twist it with your hand using some effort, there's something wrong.
Let's settle the point.. the test is whether or not the joints on the ends have slop with lateral, not rotary, motion
Old Oct 31, 2011 | 02:28 AM
ramapge's Avatar
ramapge is on a distinguished road
It's okay if you can rotate it, it's the slop you don't want, where one wheel can move and the other doesn't. The tie rod 'ties' the two wheels together. Did you find any slop using the method I described to you in another post?
Old Oct 31, 2011 | 04:30 PM
see the rod in the picture if you grab that and twist it the ends clunk up and down alot
Old Oct 31, 2011 | 04:42 PM
ramapge's Avatar
Yes, I know what you're talking about. If it rotates in the direction that the tires rotate it's fine. If it didn't when the wheels are turned the tie rod would bind. If you jack up the driver's side tire and have someone turn the steering wheel back and forth to put a little pressure on the steering components you can check for anything that's loose. If you notice the driver's side wheel turning and the passenger side staying still then the tie rod ends are worn. FYI: you'll notice that you can also twist the drag link, this is normal.
Old Oct 31, 2011 | 05:04 PM
ramapge's Avatar
Could you post a video on youtube, maybe that would clear up any confusion.
Old Oct 31, 2011 | 11:41 PM
abig84's Avatar
you can twist them like giving a indian burn to someones arm and they will move a bit. but if you can grab that bar and bounce them up and down then you got a problem. best way is to jack one front tire up at a time and then push them side to side and watch the tie rod. it shouldnt have any play in it
Old Nov 1, 2011 | 07:21 PM
so does that whole bar come off to replace the ends..mines got shcoks or something connecting to it it looks like you can only unscrew one end
