Air conditioning blows fuse
Old Feb 7, 2012 | 02:09 PM
90TBI's Avatar
90TBI is on a distinguished road
Default Air conditioning blows fuse
When I turn air conditioning or defrost on, it instantly blows the fuse under the dash. I am wondering if this is caused by a seized bearing in the A/C unit itself or if it's something simpler.
Any info would be appreicated
1990 K5 5.7
Old Feb 8, 2012 | 01:49 PM
70-K5's Avatar
70-K5 is on a distinguished road
Sounds like a short.
Old Feb 11, 2012 | 12:30 PM
abig84's Avatar
try unplugging it from the compressor and see if thatll make the problem go away. and you can even leave it that way if youre not worried about a/c. i have never seen a compressor itself cause a fuse to blow but very possible. try tracing the wires also coming off the a/c compressor. they may be pinched or smashed somewhere
Old Feb 11, 2012 | 01:05 PM
pettyfog's Avatar
1990 K5 5.7
What fuse under the dash.. AC? IF so...
{sorry, abig.. I had the screen up, left and came back to it. You're right.}
AC clutch coil.
If you had a seized bearing you'd have a helluva racket and probably a shredded belt.
Pretty sure if you unplug the connector at the compressor that will stop the fuse blowing. Then you'll know you have a shorted clutch coil.
Old Feb 12, 2012 | 07:33 PM
90TBI's Avatar
thanks guys when it's disconnected from the compressor it doesn't blow the fuse anymore.
kinson33
Mar 29, 2010 07:10 PM
DCFluX
May 16, 2008 09:20 PM
KaptainKen
Mar 23, 2008 05:03 PM
DCFluX
Oct 5, 2007 06:28 PM
myboo11009
Aug 22, 2006 04:21 PM
