air intake can.
Old Mar 15, 2007 | 11:36 PM
thevair65's Avatar
thevair65 is an unknown quantity at this point
Default air intake can.
As of now my truck has the OEM air intake system. id like to replace the stock air can with an open can. only one problem, there is a hase (reminds me of dryer vent pipe) that runs into the nozzle on the can that opens a door in the intake. the door is always open and has never worked like its suposed to. is there any way to pull my stock can and cap the hole the hose came from? how important is that assembaly? i hope this is descriptive enough if not let me know and ill see about getting a pic or more imformation.
thanks
Old Mar 15, 2007 | 11:59 PM
speeddemon560's Avatar
speeddemon560 is an unknown quantity at this point
Default RE: air intake can.
What are you talking about? Are you referring to the throttle body possibly when you were talking about the door always being open?
Old Mar 16, 2007 | 01:40 AM
thevair65's Avatar
naw the air filter can. ill take a pic and see if that helps.
Old Mar 16, 2007 | 09:50 AM
Please specify the year, model, engine of the vehicle we are discussing. From the looks of your avatar, you have an 80's K5. So you have a round element air cleaner. The door you speak of is supposed to close to pull air from around the exhaust manifolds to decrease warm up and cold starting problems. If the vacuum lines are not attached any longer, then it won't work.
You can go to an open element air cleaner, but cold, outside air is better than the hot air under the hood as far as power & efficiency go. To do it right, you'd need to ditch the factory air cleaner housing in favor of one that has a larger inlet hose to the air element, but still keep the hose routed either into the fender where yours draws its air (IIRC).
Old Mar 16, 2007 | 03:29 PM
fnirish's Avatar
fnirish is an unknown quantity at this point
That door is controlled by the IAC solenoid, which opens and closes based on how warm the engine is. If it's not working correctly, the idle will be wrong. More than likely it will be quite high. Doesn't hurt anything until you start slamming it into gear at high idle. Then it's bad for the whole driveline.
Old Mar 16, 2007 | 03:46 PM
thevair65's Avatar
oh sorry i thought i added my vehicle info to my signiture.
89 K-5 350 TBI
i think a new intake is a better option indeed. the old intake hose isnt even there anymore the old owner must not have liked it. as far as that stupid litle door goes. the only line that attaches to it is a thin metalic hose that runs from the passanger side header. it doesnt look like a vaccuum line. its too soft and doesnt fit tight. havent seen one that does fit well on any chevy.
Old Mar 16, 2007 | 04:40 PM
Yeah, that is the heat riser pipe. And there is supposed to be a vacuum line to a fitting on the underside of the lower air cleaner shell. That is what controls the valve that is in there.
Old Mar 16, 2007 | 04:42 PM
thevair65's Avatar
hmm i wonder if this could be the reason for my terrable slow starts.....
ComputerNerdBD
Headers, Intake, & Exhaust
Jan 5, 2012 04:53 PM
dimmuborgir6nik6
Oct 2, 2008 06:51 AM
il67bp
Aug 16, 2005 01:33 PM
Long Live #3
Feb 15, 2005 11:41 PM
thorbergdt
Oct 13, 2004 03:57 AM
