Belt Diagram
Old Feb 21, 2012 | 06:27 AM
Dano01's Avatar
Dano01 is on a distinguished road
Default Belt Diagram
i have a 1990 GMC Jimmy with a 350. PS, WateR pump, Crank, fan, AC, ALT. I was wondering if some one has a diagram on how the belt should go on. I have looked on gogle cant really find the one that has the same set up as i do.
Thanks
Old Feb 21, 2012 | 08:53 PM
AJBert's Avatar
There should be a diagram under the hood...
providing the sticker is still there and readable. Although, it's not too hard too figure out on your own. Pullies with grooves get the side of the belt with groves. Smooth pullies get the smooth part of the belt.
Old Feb 21, 2012 | 09:09 PM
pettyfog's Avatar
Pick the closest:
Ignore the red marks
But you dont really need a diagram once you note two givens
1. the relationship of the wrap from crank to fan pulley is always the same.. belt wraps up from driver side of crank around pass side of fan pulley.
2. You never need put belt 'over the fan'
- start from pass side, make loop of belt, put loop around crank pulley first then wrap back of belt around water pump pulley to lowest pulley on driver side.
From then on, easy. Back of belt always UNDER a smooth pulley
Old Feb 22, 2012 | 04:52 AM
Dano01's Avatar
Thanks
jaystoy
May 16, 2013 04:38 PM
lionel2
Sep 7, 2012 02:45 PM
RWCastor
Jun 1, 2011 08:14 AM
Xtreme187
Aug 13, 2010 10:27 AM
