Big Electrical problem
Old Feb 28, 2013 | 09:41 PM
85k5dblazer's Avatar
85k5dblazer is on a distinguished road
Default Big Electrical problem
I am working on a 85 k5 6.2l diesel blazer. Someone "helped" me jump start the truck but reversed the the cables. Since then the truck has not started. The dashlights do not come on, so far I have checked the alternator and starter both passed. Headlights came on when I jumper from battery to junction block on the firewall otherwise all is dead. Not sure what to check next. Any help would be appreciated.
Old Feb 28, 2013 | 10:13 PM
Twip's Avatar
did you check the main fuse?? when the cables got put on the wrong way it could have blown it.
Old Mar 1, 2013 | 12:13 AM
Mossyoaksilverado's Avatar
Mossyoaksilverado is on a distinguished road
Is there an inline fuse between the fuse box and power source... not sure if it runs to alt or battery. If so, and that is blown, you will get no power to the fuse box. Also, where did you jump to on the fuse box? Main power in? If so all the fuse box should be fine, replace the cable or inline fuse in the supply wiring.
Old Mar 1, 2013 | 10:02 PM
There is no main fuse(that I know of) and I didn't jumper to the fuse block; I jumpered to the a junction block. After doing some investigating I noticed no wire from battery to the alternator and also a fusible link that was missing by the junction block. Now I have lights and accessories but turn the key and nothing.
Old Mar 2, 2013 | 07:00 AM
rexazz2's Avatar
Fusable link at the starter ???
Old Apr 18, 2013 | 09:01 AM
watertrucker's Avatar
watertrucker is on a distinguished road
Had the same problem with an Olds diesel years ago. Was the wiring connections at the starter. Cleaned all connections and made sure everything was tight. That took care of it.
Old Apr 24, 2013 | 07:24 PM
THePaRaSiTE5771's Avatar
THePaRaSiTE5771 is on a distinguished road
This is probably going to sound obvious, but check every wire and ground under the hood. Also check the fusible link(s). Similar situation happened on my 90 K5 Blazer and the results were, fried PCM, fried alternator, fried battery cables and a melted fusible link.
Old Apr 24, 2013 | 07:53 PM
Twip's Avatar
did you ever get this fixed???
there should be a main fuse, i think it would be a MAXI 50 amp. i did the same thing one time and it killed the whole car. swapped out the fuse and away she went.
Old Jul 3, 2013 | 06:25 PM
Sorry for the late response, It is fixed. Found a fusible link about a foot long on the firewall that was missing.
And I hadnt connected the starter correctly
eagle1971
Jul 11, 2013 10:47 PM
redfyinix
Oct 11, 2011 11:32 AM
elementalnature
Dec 28, 2008 07:05 PM
butters
Sep 29, 2008 06:40 PM
2001blazer
Tires and Wheels
Mar 9, 2006 02:39 PM
