Brake Caliper not getting fluid
Old Aug 29, 2015 | 07:09 PM
kstanley's Avatar
kstanley is on a distinguished road
Default Brake Caliper not getting fluid
1993 K5 4x4 blazer: I hit a pothole in the highway recently and both the Brake and Anti-Lock light came on instantly. When I applied the brakes, the blazer pulled dangerously hard to the left. The following week, I replaced both calipers, pads and brakes lines on the front and interestingly, when I bled the passenger caliper, there was no fluid ! I reset (turned-off) the brake and anti-lock lights by jump/grounding H&A pins on the ALDL. The first time I applied the brakes, the Brake and Anti-Lock lights came back on. Why is the passenger-side caliper not receiving fluid from the master cylinder ? Is there a problem within the ABS module ? Seems odd that hitting a pothole could damage the ABS module.
One other note ... when looking at the ABS module on the driver-side fender-well, I did notice a small pin pushed out on the bottom of the module. I pushed it back in to match the one next to it. Still, no fluid is getting to the front passenger caliper. Any suggestions ?
Old Aug 30, 2015 | 12:53 AM
kstanley's Avatar
Default Code Retrieval
I retrieved a code "61" from the ABS system tonight:
Code 61 = Pump Motor Run Fault
What is the fix for a Code 61 ?
Old Sep 1, 2015 | 07:19 PM
abig84's Avatar
i cant really find much on it on identifix. mostly generic responses
1. Test the brake lines for a good ground, this is how the Electro-Hydraulic Control Unit (EHCU) is grounded.
2. If OK, replace the EHCU.
thats actually pretty weird if it grounds off themetal brake lines
phxjosh
Mar 8, 2018 12:46 AM
bertrenolds
Jan 6, 2009 04:55 PM
pigmak
Nov 4, 2007 07:21 PM
pigmak
Nov 4, 2007 02:26 PM
lemon blazer
Aug 7, 2007 08:31 AM
