broken shifter mounting tab
Old Jul 21, 2012 | 06:06 PM
stevesk5's Avatar
stevesk5 is on a distinguished road
Default broken shifter mounting tab
Hey all,
I am new to the forum and hope to be of some help here. I recently picked up my 1st k5 last month. She s a 79 with the cheyenne package and a 400. Its a bit rough in some areas but I am slowly getting the kinks ironed out as time and money allow. Right now I am stumped on an issue and I am hoping for some advice. This truck is an auto shift and the mounting ear that holds the shifter in place with a press pin has broken. I have the piece but the spring that provides tension is also missing. I can see that this sleeve CAN be removed but my question is how? I can grab a replacement at the bone yard but I need to get this old one off first...any thoughts?
I could use jb weld but this does not address the problem of getting the tension spring back in.
Thanks guys!
Old Jul 21, 2012 | 08:11 PM
You are going to have to dismantle the steering column to get to the shift collar. There are a number of well documented how-to's on tilt steering column rebuilds on the internet, however the standard GM steering column isn't as well covered. There are some similarities and the standard non-tilt column is much less complicated on the inside.
Old Jul 23, 2012 | 11:18 AM
70-K5's Avatar
70-K5 is on a distinguished road
Ditch the column shifter and put in a floor mega-truck-shifter !
Old Jul 23, 2012 | 08:10 PM
abig84's Avatar
that or just replace the entire column if it seems to be to big of a job for you. ive torn apart a few columns and most circumstances i just replace the entire thing. pick and pulls are cheaper to get them at but if you go to a already pulled place they run about 100
Old Jul 24, 2012 | 08:47 AM
stevesk5's Avatar
I appreciate all the replies!
around here (and probably most places) people seem to destroy columns at the junk yard. Its like they go in for a one or two pieces, and destroy the whole unit in the process. I was in the yard last weekend and out of 9 trucks, only 1 column was viable. The column rebuild is certainly w/in my mechanical abilities, I am just wondering if it is withing the limits of my patients!
Old Jul 24, 2012 | 01:30 PM
abig84's Avatar
if you dont have a chiltons or something with a good break down picture take pictures as you go along to remember where everything goes. as far as special tools go you will need a steering wheel puller for the plate behind the wheel and i think there are some torx screws back there
cb_murray
Jan 8, 2015 06:41 PM
jasedude
Nov 24, 2010 04:03 PM
HHimmy
Aug 5, 2010 06:51 AM
rbcar1
Dec 13, 2009 10:20 AM
oisinirish
May 20, 2009 08:13 PM
