Carb Issues
Old Dec 6, 2008 | 01:41 PM
bgk95691's Avatar
bgk95691 is an unknown quantity at this point
Default Carb Issues
I have a 1986 Blazer K5 with a rochester 4bbl model e4me. I installed a plenum air intake on it with an amsoil cone filter. It is also cold outside about 40 degrees. The blazer used to run extremely good but now it cuts out when you stomp on it, almost dying for a few seconds then it catches up and accelerates. My question is what do I need to change or adjust?
Old Dec 6, 2008 | 05:52 PM
Default RE: Carb Issues
*Moving to Fullsize Tech* - The DIY Submissions area is for submission of complete DIY articles only and not for tech help.
Unless the new intake is hitting on something, it sounds as though the accelerator pump is not working properly anymore. This would cause a noticeable off idle stumble. It may be as easy as dropping in a new accelerator pump, but I would buy a complete rebuild kit and rebuild the carb.
Brandon Smith
Dec 22, 2013 12:33 PM
boomtruck97
Engine & Internal
Jun 29, 2006 02:45 PM
Manley_pm
Dec 19, 2005 11:18 PM
jotajota
Engine & Internal
Dec 11, 2005 11:45 AM
zero psi
Engine & Internal
Dec 11, 2005 12:20 AM
