Electric Fuel Pump 89 K5 Blazer 350
Old May 12, 2009 | 01:57 AM
sherryannK5's Avatar
sherryannK5 is on a distinguished road
Default Electric Fuel Pump 89 K5 Blazer 350
Can an in tank fuel pump be replaced with an inline fuel pump without removing the tank? Can someone please tell me where the fuse and relay are located? Thank You!
Old May 12, 2009 | 07:29 AM
I would not replace it without doing something different with the pump in the tank. The pump will be a restriction.
The fuse should be under the dash and the relay, I think, is on the firewall.
Old May 12, 2009 | 10:41 PM
TomSawyer's Avatar
TomSawyer is on a distinguished road
Drop the tank and do it the right way, it's not as bad as you may think it's gonna be. I've never had to test the relay's but getting a good manual is the way to go, your gonna need it anyway.
Old May 12, 2009 | 10:52 PM
bandidolenny's Avatar
Unless you are converting to a carb... you need to use an OEM style in tank pump. It's not that hard of a job, just siphon all the gas out before lowering the tank.
Old May 13, 2009 | 03:43 AM
kiwiblazer's Avatar
Welcome from down under.
Crossroad
Aug 23, 2014 03:37 PM
tech180
Feb 2, 2013 10:23 AM
dman001948
24
Feb 17, 2012 08:55 PM
toyblazervt
Nov 28, 2010 05:07 PM
punx.inc
Dec 25, 2007 12:07 AM
