Emissions help
Old Jan 25, 2006 | 06:29 PM
codereddanger84's Avatar
codereddanger84 is an unknown quantity at this point
Default Emissions help
hey guys im new here i have a 93 full size blazer and it failed emmisions bad
Load Load Std Idle Idle Std
(HC) 727 220 2386 220
(CO) 13.61 1.20 12.01 1.20
Those are the results i got from the test where should i start. About three months ago i replaced the plugs, plug wires, cap, rotor, ign. module, blaster coil, fuel filter, and fuel system treatment. any help would be great thanks.
Old Jan 25, 2006 | 06:52 PM
RedBlaze's Avatar
From: Atlantic, NC (eastside whats crack-a-lackin!)
RedBlaze is an unknown quantity at this point
Default RE: Emissions help
Does it still have the original catalytic converter on it?? If so it might be time for a new one. Also, next time make sure you have a oil change done shortly before you take the test. Believe or not this will help some. You might wanna clean our your egr valve also, and maybe do a seafoam treatment.
2000Bansheeboy
Jan 28, 2011 10:54 AM
legend9391
Jan 4, 2011 07:51 PM
pmezo
30
Dec 9, 2010 12:39 AM
dyeraudio
Mar 7, 2009 07:15 PM
cr8390
Nov 7, 2008 08:45 PM
