Front end clicking?
Old Dec 28, 2020 | 07:58 AM
RSivley's Avatar
RSivley is on a distinguished road
Question Front end clicking?
I'm new to this group so if this has been discussed i apologize, i have a 1976 K5 4x4, it has a loud clicking noise from the right front. When i put the whole truck on stands the noise goes away. its definitely a drive line noise just not sure what it could be. Brakes are all new, wheels are not rubbing. any thoughts??
Old Dec 28, 2020 | 11:54 AM
Is it a full-time 4x4 (NP203), or does it have locking hubs? Sounds like it could be a bad axle shaft u-joint. Is it worse when you turn?
Old Dec 28, 2020 | 12:38 PM
RSivley's Avatar
Yes, its a NP203 with automatic hubs and is clicking no matter if i turn or not, I do think it gets a little worse when turning. i might switch to manual Warn hub locks if i have to pull it apart.
Old Dec 28, 2020 | 12:48 PM
Unless it has a part-time kit installed, you can't use manual hubs. It won't move unless you use one of the LOC positions on the shifter, which would defeat the purpose.
I would visually inspect the joints in the front axles, and maybe jack the front end up and turn the wheels to see if you can duplicate the noise. Also check the driveshaft u-joints, but if those were bad, you would probably get a vibration at road speeds rather than a clicking noise.
Old Dec 28, 2020 | 01:03 PM
RSivley's Avatar
Ok thanks, it doesn't make the noise when the truck is off the ground, it has a 12" lift so i have new rear drive shaft and rebuilt front drive shaft but i haven't checked the axle u joints yet.
Old Dec 28, 2020 | 01:53 PM
Let's see some pictures of that beast!
Old Dec 29, 2020 | 06:45 AM
Tregrad's Avatar
Tregrad is on a distinguished road
12" NICE, i had a 78 with 14 years ago. Funnest damn truck ever 40" groundhogs on it,gettin a chub thinkin about it lmao, post a few pics.
i agree with Tom, sounds like u-joints either on the end of the axl or drive line but since they are new.....
while you got it in the air put a jack under the tire and give it some action and inspect the front end parts. "ticking" is usually u-joints or hubs.
is it a constant "ticking" or just when you turn a certain way?
remember we want some pics :-)
Old Dec 29, 2020 | 07:15 AM
RSivley's Avatar
Default Pics
pictures during and after paint. sitting on 38s, still a work in progress!!
Old Dec 29, 2020 | 08:28 AM
Thats a very nice blazer you got!!
Hope the problem gets resolved, got some good help around here.
Old Dec 29, 2020 | 08:43 AM
Tregrad's Avatar
Very nice man, I just got back into the blazer game, bought a 72 with an gen3 LS swap in it. Body looks like a rat rod and rough as hell but i got a smokin deal on it so when teh body is done it will be awesome. Love the lift on yours, its prerfect.
