Gauges arn't working!
Old Jun 28, 2010 | 01:41 PM
K5countryboy's Avatar
K5countryboy is on a distinguished road
Default Gauges arn't working!
I just did a engine swap, and none of my gauges aren't working. Battery gauge, water temp, gas gauge, and i cant find the wire for my oil selonid. any help of wire diagram or pics of the wires would be great. And yes my water temp wire is hooked up.
Old Jun 28, 2010 | 02:31 PM
What are you driving?
Have you checked the 'gauges' fuse?
Old Jun 28, 2010 | 04:04 PM
1986 k5 blazer w/ a 350 out of a 79 k5 just swapped out last week everything is connected like it should be. none of my gauges are working and i cant find the oil solenoid wire
Old Jun 28, 2010 | 04:49 PM
You really should check your fuses. The gage/idle fuse (20A) drives pretty much the whole cluster.
As far as the oil pressure sending unit wire, it should come out of the wiring harness that crosses over the top of the engine mounted to the firewall. It should drop down to the sending unit which is located on the back of the engine between the distributor & the brake booster.
Old Jun 29, 2010 | 01:20 PM
I cant figure out which wire it is. I have a lot of extra wires hanging cause i did just a basic swap. I took out the ac, cruise control, and smog pump.
Old Jun 29, 2010 | 01:34 PM
Ok, The fuse was blown. I put another one in and it blew immediately. Bad ground maybe, or what?
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
frostblazer
Jun 15, 2010 10:25 PM
azari215
Feb 12, 2009 09:31 PM
pndurbin
Jan 15, 2008 10:18 AM
weston
Nov 28, 2006 12:28 PM
