I Need Help Please
Old Feb 26, 2009 | 04:19 PM
sensesfail85's Avatar
sensesfail85 is an unknown quantity at this point
Default I Need Help Please
I'm picking up my 73 k5 tonight, the front drive shaft is uninstalled, I was wondering if anyone would know what size the bolts are to put that in?
Old Feb 26, 2009 | 04:32 PM
Default RE: I Need Help Please
You first may want to investigate why the front driveshaft was uninstalled...
Old Feb 26, 2009 | 04:34 PM
i already know why it was. the guy thought it was full time 4wd.
Old Feb 26, 2009 | 04:36 PM
BVFD25's Avatar
BVFD25 is an unknown quantity at this point
I do not know about a 73, but my 85 has the U-bolts with 7/16" nuts on it.
Old Feb 26, 2009 | 04:56 PM
is that on both sides?
Old Feb 26, 2009 | 05:01 PM
BVFD25's Avatar
yes. there is two on both ends of the drive shaft, two at the axle and two at the transfer case.
Old Feb 26, 2009 | 05:03 PM
thanks i will check it out tonight when i pick it up
Old Feb 26, 2009 | 05:11 PM
ORIGINAL: sensesfail85
Yes, but with the NP203 full time 4wd in stock form, you cannot remove the front driveshaft and hope to move... Just trying to cover the bases so you do not end up with an unexpected problem.
And yes, they are typically are a hex nuts which require a 7/16" wrench (not a 7/16" thread) that thread onto a U shaped strap as pictured below:
This is a picture of the front driveshaft on my 74 K5 where it connects to the front axle (Dana 44). I believe that the other end is the exact same arrangement.
Old Feb 26, 2009 | 05:31 PM
its not full time awd, he thought it was before. do you happen to know what thread pitch the bolts are?
Old Feb 26, 2009 | 06:41 PM
It is a UNF thread. I do not know the exact thread size though.
