Ignition timing too high
I just picked up an 89 Jimmy. I went to get it smogged today and it failed because the ignition timing is too high at 800 RPM and they said it should be at 600. Is there anything I can do to fix this or do I need to take it to a mechanic? Also the engine has been replaced with a 383 if that matters
pretty much all i know is that it is still throttle body injection like the original 350 and it has vortec heads. i probably should of got more info on it when i bought it, but i needed a vehicle right away so i bought this one. and it runs amazing. just this one thing i have to figure out
Are you in Oakland, CA? I thought they had strict rules about engine swaps...
Anyways, the ignition timing is a relationship between spark and pistion position. You said that it needs to be at 600rpm vs. 800rpm, that is a idle setting.
My $0.02 is take it to a mechanic.
You can advance the timing which will increase the idle speed.You have to plug or disconnect the computer cant remeber which hopefully some can help with that.If its not a timing issue it could possibly be tps.
AndrewO1991
06-04-2013 05:59 PM
drblaze
18
06-22-2011 02:58 PM
RIFLEMAN 308
07-31-2010 04:42 PM
97 POS
03-31-2010 11:41 AM
