No Fuel?
Old Aug 14, 2010 | 03:42 AM
figuema's Avatar
figuema is on a distinguished road
Unhappy No Fuel?
Just purchased my 91' K5 replaced the exhaust manifold gaskets because had leak. took it out for a drive and noticed it very sluggish and under powered. got home and died, i can hear the fuel pump but am not getting any fuel out of the injectors. What can it be? Fuel pressure regulator?
Old Aug 14, 2010 | 07:15 AM
blueblazer1982's Avatar
blueblazer1982 is on a distinguished road
did it run itself out of fuel? i know those pumps in the tanks ususally are one and done once they run out of fuel in the k5.
Old Aug 14, 2010 | 03:20 PM
figuema's Avatar
No it has half a tank, and im getting fuel up to the TBI? But the injectors don't spray?
Old Aug 14, 2010 | 04:43 PM
Have you tested the fuel pressure? It should be around 10psi. You may need to install an adapter to test the fuel pressure.
Old Aug 16, 2010 | 12:16 AM
figuema's Avatar
Tested fuel pressure, reading 11 psi. I went ahead and bought the rebuild kit for the TBI, installed it and now it starts but only one injector is spraying?...There's a blue and red wire on one injector and green and white on the other. The blue and green wires are the ones that supply current to the injectors correct? I have current on the blue wire but not on the green. I even checked from the ECM and voltage comes out from the blue but not the green? I opened up the ECM and found an aftermarket Jet Perfomance Chip in it. Am I gonna need a new ECM?
Old Aug 16, 2010 | 06:26 AM
You should have +12V to each of the injectors through the white and red wires. The grounding of the injectors takes place through the ECM on the blue and green wires.
Old Aug 19, 2010 | 01:00 AM
figuema's Avatar
Well I checked the red and white wires, and was getting voltage on the red but not the white. I saw where these wires connect to a pink and black wire and checked voltage there, which I had. I proceeded to take off all tape and found that between the injectors and the pink and black wire the injector wires had butt connectors and the white wire had gotten disconnected!! Stripped both ends and soldered the wire. It's running like a champ again!! Thanks for all the help!!!
Old Aug 19, 2010 | 06:43 AM
Very nice!! Glad to help!
95jblaze
Aug 27, 2011 03:46 PM
cide
Nov 7, 2009 01:26 PM
mytruck2
Dec 13, 2006 04:50 PM
Nations81
Aug 18, 2006 03:03 PM
jlinder
Aug 21, 2005 11:08 AM
